Intel vPro® Platform
3079 Discussions
how to Setup Enterprise mode
I had try to setup enterprise mode of Vpro by HP 6910P 2 PCS.
SW: Intel_vPro_cPro_Demo
Refer document is amt_provisioning.pdf
Q: we can find the AMT machine, but we can't connect the machine. Neither Intel DTK nor http.
Any expert can give me some step by step procedure, sincerely thanks ?
I've got a couple of questions for you. Are you using AMT Director or another ISV to provision your clients? Are you using TLS or non-TLS based security?
Intel AMT Director, has try ISV HP OpenView can't find the AMT machine.
TLS security, PID and PPS
Do you have a CA configured and did you add the root certificate to AMT Director?
You may want to try creating a non-TLS profile and try provisioning a client with it. If that works ok you will want to verify your CA is working properly and that you have root certificate loaded in AMT Director so that it can properly provision your client.
Thank you for your message, this issue were fixed.
