- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
thanks
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello, kostas1,
I am glad to know you are using Intel® vPro products.
Intel® AMT feature allows the remote access with wired and wireless connections on Intel® network cards only.
Do you mind giving more details about the intel management center software that you refer to? If you are trying to access the machine from the browser (Intel® AMT WebUI), you need to type: https://IP address:16993.
For the configuration, we just need to access the MEBx BIOS and create a new password.
If further assistance is necessary, please run Intel® System Support Utility for Windows and send me the log.
https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
If you get configuration issues in MEBx, please send me pictures of the current settings.
Miguel C.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi Miguel, i installed mesh commander locally (on the toughpad) and i set up a wireless profile using the mesh commander, now it works but ONLY when windows is running if i select as action to boot into bios (from another pc) it loses connectivity.
in a few words remote desktop and all works only when windows are on and is using the windows wireless profile, if i restart i cant see anything until it boots in windows (i cant boot into bios or anything by using kvm using mesh commander)
I have used many computers with AMT before but they all had wired lan and either i configured the ip in bios or it was shared ip with OS never used with wireless card before, and yes this windows pad has intel cards and everything AMT (processor motherboatd etc)
oh and also this doesnt work either when windows arent running but for example the toughpad is off or is in bios screen
http://192.168.100.35:16992/index.htm
it seems the wireless card can only connect to the network when windows are running and when not, it disconnects
please help me on this !
here is the log thanks
# SSU Scan Information
Scan Info:
Version:"3.0.0.2"
Date:"02/08/2024"
Time:"00:00:16.2887555"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Panasonic Corporation"
BIOS Mode:"UEFI"
BIOS Version/Date:"American Megatrends Inc. V1.00L25 M30 , 02/10/2019 12:00 πμ"
CD or DVD:"ELBY CLONEDRIVE SCSI CdRom Device"
Embedded Controller Version:"1.0"
Platform Role:"Mobile"
Processor:"Intel(R) Core(TM) i5-4302Y CPU @ 1.60GHz , GenuineIntel"
Secure Boot State:"Off"
SMBIOS Version:"2.7"
Sound Card:"High Definition Audio Device"
System Manufacturer:"Panasonic Corporation"
System Model:"FZ-M1CDB49E3"
System SKU:"FZ-M1CDB49E3"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "Microsoft Basic Display Adapter"
Adapter Compatibility:"(Standard display types)"
Adapter DAC Type:
Adapter RAM:"0,00 GB"
Bits Per Pixel:"32"
Caption:"Microsoft Basic Display Adapter"
CoInstallers:"display.inf,MSBDA,Not Available,Not Available"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"BasicDisplay.sys"
Driver Date:"06/21/2006 03:00 πμ"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\basicdisplay.inf_amd64_5103ac179273be89\BasicDisplay.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.17763.1"
INF:"display.inf"
INF Section:"MSBDA"
Install Date:"Not Available"
Installed Drivers:"Not Available"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"(Standard display types)"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_0A1E&SUBSYS_833810F7&REV_0B\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"64 Hz"
Refresh Rate - Maximum:"64 Hz"
Refresh Rate - Minimum:"64 Hz"
Resolution:"1280 X 800"
Scan Mode:"Noninterlaced"
Service Name:"BasicDisplay"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:
- "Memory"
Physical Memory (Available):"2,37 GB"
Physical Memory (Installed):"4,015625 GB"
Physical Memory (Total):"3,89 GB"
- "Flash ROM"
Capacity:"0,015625 GB"
Channel:"Flash ROM"
Configured Clock Speed:"0 MHz"
Configured Voltage:"Not Available"
Data Width:"8 bits"
Form Factor:"TSOP"
Interleave Position:"Noninterleaved"
Manufacturer:"Not Available"
Maximum Voltage:"Not Available"
Memory Type:"Flash11"
Minimum Voltage:"Not Available"
Part Number:"Not Available"
Serial Number:"Not Available"
Status:"Not Available"
Type:"Nonvolatile"
- "Onboard"
Capacity:"2 GB"
Channel:"Onboard"
Configured Clock Speed:"1600 MHz"
Data Width:"64 bits"
Form Factor:"TSOP"
Interleave Position:"Not Available"
Manufacturer:"0000"
Memory Type:"DDR3"
Part Number:"CF9876543210"
Serial Number:"00000002"
Type:"Synchronous"
- "Onboard"
Capacity:"2 GB"
Channel:"Onboard"
Form Factor:"TSOP"
Manufacturer:"0000"
Memory Type:"DDR3"
Serial Number:"00000000"
Type:"Synchronous"
- "Motherboard"
BIOS:"V1.00L25 M30, MATBIO - 1072009"
Caption:"Motherboard"
Chipset:"Not Available"
Date:"10/02/2019 03:00 πμ"
Model:"Not Available"
PNP Device ID:"Not Available"
Product:"FZM1-1"
Serial Number:"2291AAA26A20503"
Status:"OK"
Version:"1"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"21.10.1.0"
- "EM7305"
Caption:"EM7305"
CoInstallers:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"No"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"cxwmbclass.sys"
Driver Date:"12/09/2019 12:00 πμ"
Driver Path:"C:\Windows\system32\drivers\cxwmbclass.sys"
Driver Version:"10.0.17763.771"
Index:"0001"
INF:"netwmbclass.inf"
INF Section:"wmbclass.ndi"
Installed:"Yes"
IP Address:"Not Available"
IP Subnet:"Not Available"
Last Reset:"02/08/2024 01:04 πμ"
MAC Address:"94:BB:84:5C:51:56"
Manufacturer:"Microsoft"
Net Connection ID:"Cellular"
NetCfgInstanceId:"{7FEC442D-4AEA-4CD3-BC61-436F4146207F}"
PNP Device ID:"USB\VID_1199&PID_9041&MI_0C\6&278D781F&0&000C"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Not Available"
Power Management Supported:"No"
Product Type:"Generic Mobile Broadband Adapter"
Service Name:"cxwmbclass"
Status:"Enabled"
Type:"Wireless"
- "Service Bindings"
Client for Microsoft Networks:
File and Printer Sharing for Microsoft Networks:
Internet Protocol Version 4 (TCP/IPv4):
Internet Protocol Version 6 (TCP/IPv6):
- "Settings"
*SelectiveSuspend:Selective Suspend:"Enabled (1)"
- "Intel(R) Dual Band Wireless-AC 7260"
Access Point:"e4:c3:2a:31:c3:4f"
Authentication:"WPA2-Personal"
- "Caption":"Intel(R) Dual Band Wireless-AC 7260"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Dual+Band+Wireless+AC+7260"
Channel:"40"
Cipher:"CCMP"
Connection Mode:"Auto Connect"
Default IP Gateway:"192.168.100.100"
DHCP Enabled:"Yes"
DHCP Lease Expires:"02/08/2024 03:04 πμ"
DHCP Lease Obtained:"02/08/2024 01:04 πμ"
DHCP Server:"192.168.100.1"
Driver:"Netwbw02.sys"
Driver Date:"04/29/2019 12:00 πμ"
Driver Path:"C:\Windows\system32\drivers\Netwbw02.sys"
Driver Provider:"Intel"
Driver Version:"18.33.17.1"
Index:"0002"
INF:"oem25.inf"
INF Section:"Install_MPCIEX_GENNGFF_7260_AC_2x2_HMC_WINB_64_AC"
Installed:"Yes"
IP Address:"192.168.100.35;fe80::3999:1cb3:430:5bf9"
IP Subnet:"255.255.255.0;64"
MAC Address:"58:91:CF:78:FA:FF"
Manufacturer:"Intel Corporation"
Net Connection ID:"Wi-Fi"
NetCfgInstanceId:"{EBE7D80C-A748-4BAC-A542-FE0A6DE9D18A}"
Network Name:"asiawatcher.net"
Network Type:"Infrastructure"
PNP Device ID:"PCI\VEN_8086&DEV_08B1&SUBSYS_C0708086&REV_BB\5891CFFFFF78FAFF00"
Power Management (Low Power):"Active: Yes, Enable: Yes"
Power Management (Wake On LAN):"Active: Yes, Enable: No"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Product Type:"Intel(R) Dual Band Wireless-AC 7260"
Profile:"asiawatcher.net"
Radio Type:"802.11ac"
Receive Rate:"351 Mbps"
Service Name:"NETwNb64"
Signal Strength:"75%"
State:"connected"
Status:"Enabled"
Transmit Rate:"351 Mbps"
Type:"Ethernet 802.3"
Link-Layer Topology Discovery Mapper I/O Driver:
Link-Layer Topology Discovery Responder:
Microsoft LLDP Protocol Driver:
QoS Packet Scheduler:
- "Settings"
*DeviceSleepOnDisconnect:Sleep on WoWLAN Disconnect:"Disabled (0)"
*PacketCoalescing:Packet Coalescing:"Enabled (1)"
*PMARPOffload:ARP offload for WoWLAN:"Enabled (1)"
*PMNSOffload:NS offload for WoWLAN:"Enabled (1)"
*PMWiFiRekeyOffload:GTK rekeying for WoWLAN:"Enabled (1)"
*WakeOnMagicPacket:Wake on Magic Packet:"Enabled (1)"
*WakeOnPattern:Wake on Pattern Match:"Enabled (1)"
BT3HSMode:Bluetooth(R) AMP:"Enabled (1)"
ChannelWidth24:Channel Width for 2.4GHz:"Auto (1)"
ChannelWidth52:Channel Width for 5GHz:"Auto (1)"
CtsToItself:Mixed Mode Protection:"RTS/CTS Enabled (0)"
FatChannelIntolerant:Fat Channel Intolerant:"Disabled (0)"
IbssQosEnabled:Ad Hoc QoS Mode:"WMM Disabled (0)"
IbssTxPower:Transmit Power:"5. Highest (100)"
IEEE11nMode:802.11n/ac Wireless Mode:"802.11ac (2)"
RoamAggressiveness:Roaming Aggressiveness:"3. Medium (2)"
RoamingPreferredBandType:Preferred Band:"1. No Preference (0)"
ThroughputBoosterEnabled:Throughput Booster:"Disabled (0)"
uAPSDSupport:U-APSD support:"Disabled (0)"
WirelessMode:802.11a/b/g Wireless Mode:"6. Dual Band 802.11a/b/g (34)"
- "Operating System"
.Net Framework Version:"4.0,4.8"
Boot Device:"\Device\HarddiskVolume2"
Internet Browser:"Google Chrome,121.0, Internet Explorer,11.914"
Locale:"Greece"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 10 Enterprise LTSC"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"1,38 GB"
Physical Memory (Available):"2,38 GB"
System Directory:"C:\Windows\system32"
Version:"10.0.17763 Build 17763"
Virtual Memory (Available):"3,94 GB"
Virtual Memory (Total):"5,27 GB"
Windows Directory:"C:\Windows"
- "Installed Updates"
KB2151757:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [6/2/2024]"
KB2151757:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [6/2/2024]"
KB2467173:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [6/2/2024]"
KB2467173:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [6/2/2024]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB4486153:"Update [12/15/2019]"
KB4516115:"Security Update [12/15/2019]"
KB4523204:"Security Update [12/15/2019]"
KB4530715:"Security Update [12/15/2019]"
KB4530742:"Update [12/15/2019]"
KB4533001:"Update [12/15/2019]"
KB982573:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [6/2/2024]"
KB982573:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [6/2/2024]"
SP1:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [Not Available]"
SP1:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [Not Available]"
- "Processor"
- "Intel(R) Core(TM) i5-4302Y CPU @ 1.60GHz"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 69 Stepping 1"
- "Chipset Name":"Intel(R) Core(TM) i5-4302Y CPU @ 1.60GHz"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Core+i5+4302Y+CPU+"
CPU Speed:"0,798 GHz"
Current Voltage:"1.8 volts"
Driver:"Not Available"
Driver Date:"04/21/2009 12:00 πμ"
Driver Path:"C:\Windows\system32\drivers\intelppm.sys"
Driver Version:"10.0.17763.503"
Ext. Family:"Not Available"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Level 1 Cache:"2 x 128 KB"
Level 2 Cache:"2 x 512 KB"
Level 3 Cache:"3 MB"
Load:"29%"
Manufacturer:"GenuineIntel"
Model:"69"
Name:"Intel(R) Core(TM) i5-4302Y CPU @ 1.60GHz"
Number of Cores:"2"
Number of Cores Enabled:"2"
Number of Logical Processors:"4"
Part Number:"None"
Processor ID:"BFEBFBFF00040651"
Revision:"17665"
Service Name:"intelppm"
Status:"OK"
Stepping:"1"
- "Storage"
Not Available:
...#SSU#...
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
it seems the wireless card can only connect to the network when windows are running and when not, it disconnects (even with power supply connected)
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello, kostas1,
Intel® AMT WebUI only allows the remote access to final computers when they are in Windows. Out of Band (OOB) connection is not possible. Intel® AMT WebUI is the basic software available.
Port 16992 has been removed; we need to use port 16993. Systems running Intel® AMT version 12 or higher only support https connections.
For business environments, Intel released the software Intel® Endpoint Management Assistant (EMA), it allows the OOB connections. Only systems with AMT version 11.8.79 or higher are supported. The client machine needs to run Windows Server 2019 or 2022, it is necessary to create a database with SQL 2017 or higher.
More details: Intel® Endpoint Management Assistant (Intel® EMA) Server Installation and Maintenance Guide
I will gladly provide further assistance if necessary.
Miguel C.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi there and thanks for your time,
I have used the webUI even when other pc's were off before and i powered them on using the webUI so i dont know why this isnt possible.
So there isnt a way to go into bios or mount remote storage when pc isnt running windows? whats the point then ? i have successfully done that with pc's running even older amt version such as 9.1 there must be some other way otherwise there is no point i could use anydesk only then.
cheers
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello, kostas1,
The OOB connection is possible; however, a web application such as Intel® EMA or third-party software is necessary.
I am adding the documentation taking about the changes.
Accessing Intel AMT via the WebUI Interface
Miguel C.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello, kostas1,
If further assistance is necessary, do not hesitate to reply.
Miguel C.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello, kostas1,
I hope this post finds you well. Please reply or create a new forum if further assistance is necessary.
Miguel C.
![](/skins/images/3344F5B3B76C91485ED0E980FD0CA95E/responsive_peak/images/icon_anonymous_message.png)
