Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3091 Discussions
unexpected behavior interface down not resetting counters while other vendors do...
FIsma2
New User
I am trying to use Linux command 'ifconfig interface down' to reset the counters of installed pci, but the counters are not resetting to zero
checked out the hardware and drivers...
Tested on Ubuntu 17.10 / Ubuntu 16.04.4 LTS
19-Ubuntu SMP Wed Oct 11 18:35:14 UTC 2017
Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
lspci
01:00.0 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
lshw
*-pci:2
description: PCI bridge
product: 8 Series/C220 Series Chipset Family PCI Express Root Port # 6
vendor: Intel Corporation
ifconfig enp1s0
enp1s0: flags=4163 mtu 1500
inet 144.174.28.73 netmask 255.255.255.0 broadcast 0.0.0.0
ether 90:e2:ba:44:35:5a txqueuelen 1000 (Ethernet)
RX packets 1443511343 bytes 1927426776123 (1.9 TB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 288024542 bytes 45121362422 (45.1 GB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
ifconfig enp1s0 down
ifconfig enp1s0
enp1s0: flags=4098 mtu 1500
RX packets 1443857046 bytes 1927485545523 (1.9 TB) >> NOT RESETTING
TX packets 288024543 bytes 45121362464 (45.1 GB) >> NOT RESETTING
Hello Seismael,
Thank you for posting in Intel Wired Ethernet Communities. Please try shutting the interface down and loading the module: ifconfig down; then modprobe -r ixgbe; followed by modprobe ixgbe; and ifconfig up.
If this does not work please post ethtool -i output, and provide the product code from the adapter as seen in the following https://www.intel.com/content/www/us/en/support/articles/000007060/network-and-i-o/ethernet-products.html link.
Daniel D
Intel Customer Support
Agent under contract to Intel
Hello Seismael,
Do you still need assistance with the interface on the 82599ES Ethernet Controller? Please let us know if this issue is resolved, or you still have any other concerns. Please do not hesitate to contact us with any other questions.
Daniel D
Hello Seismael,
Is this controller integrated into an OEM adapter? You might also find help from the product vendor. If you have any questions please let us know.
Daniel D
