Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3092 Discussions
vPro Flash Module Development
Hi Experts,
I'm looking for some informations around vPro Falsh Module that is available on vPro Laptops.
My questions are relative to the possibility to implement some program code inside the Flash :
- Is it possible to write Executable Code on the Flash?
- If so, would it be a 16 or 32 bits code ?
- Can we implement Boot-Block code as MBR on the Flash so we would be abble to boot on the Flash rather than the Drive or USB Key.
- Can we implement a BIOS EFI Extension code on the Flash ?
- Can we use a NetworkBootProgram PXE for exemple on our code ?
- What size could we expect to use on the Flash to inject our code in the vPro Flash Module ?
- Is there a Technical Reference Document for the Flash vPro Module we could use ?
Thanks a lot for your help on this !
Damien
Hello Damien,
For this type of question, I'm guessing that you'll probably get a better response on the Manageability Software Development forum. I can tell you that, for security reasons, it's not possible to write code to execute within the Manageability Engine though.
http://software.intel.com/en-us/forums/manageability-software-development/ http://software.intel.com/en-us/forums/manageability-software-development/
Trevor Sullivan
Systems Engineer
OfficeMax Corporation
JLodh
New Contributor II
Hi Damien!
I've forwarded your query to the concerned person however you might want to do the needful as advised by Trevor.
Trevor - Thanks champ for pitching in!
Warm Regards,
Javed Lodhi
Intel Go Green, Save The Environment!
