Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3090 Discussions
workstation processors and server processors
I am shopping to create a network with a server and 3 workstations. Can the workstations be AMD and the Server be Intel Celeron?
JLodh
New Contributor II
Hi Weber,
Intel and AMD are very much interoperable with each other so you can have a mesh of servers and clients from both Intel and AMD at the same time however since you mentioned that you are hoping to buy a Celeron based system for use as server, I have to ask you .. What services do you plan to host on this server since Intel Celeron processor is a desktop processor and it would not be wise to use it as a server unless the services you plan to host do not require much computing power.
Warm Regards,
Javed Lodhi
Intel Go Green, Save The Environment!
