Items with no label
3340 Discussions
A CONIX Research Center program for combining point clouds from multiple 400 Series cameras
MartyG
Hi everyone,
I discovered a program that enables stitching together of point clouds from multiple RealSense 400 Series cameras over an Ethernet network, created by the CONIX Research Center at Carnegie Mellon, so thought I would share it with the community.
https://github.com/conix-center/pointcloud_stitching
The method used (each camera has its own PC, and the data is sent to another PC for final processing) is similar to the process used by Intel in January 2018 for their 'volumetric capture' demo at the Sundance festival.
https://realsense.intel.com/intel-realsense-volumetric-capture/
On the subject of ethernet, you may also be interested in an example program in the RealSense SDK called EtherSense.
https://github.com/krejov100/EtherSense
