Items with no label
3340 Discussions
Set up a C++ project in VS2017 from scratch
JAlli3
Hi, as the title says, I'm trying to set up a project in from scratch without success. I've downloaded the latest SDK from GitHub and can get the examples running no problem. I'm using a C++ toolkit called openFrameworks and need to integrate the SDK into an existing project.
So far I've added librealsense-2.18.1\include\librealsense2 to the C/C++ -> Additional Included Directories and pointed to librealsense-2.18.1\Build\Release in the Linker -> Additional Library Directories to connect to the realsense2.lib file.
I've tried some of the code from this page - https://github.com/IntelRealSense/librealsense/tree/master/examples/capture
But pipe.start(); leads to lots of unresolved external symbol errors e.g:
Error - LNK2001 - unresolved external symbol _rs2_get_failed_function - ofxIntelRealSense.obj
What do I have to link to in order to get started? All I need to do is get the depth texture from 2 cameras.
Details:
Windows 10 with VS2017
RealSense D435 with latest firmware
SDK 2.18.1 downloaded from GitHub
JAlli3
Thanks for your reply. It seems like the only thing I was missing was the following in my RealSense class:
#pragma comment(lib, "realsense2.lib")
Not sure why this is necessary. I thought that linking to the correct directory was enough.
MartyG
This is a subject that admittedly is not explained in a beginner-friendly way. I should mention that I do not usually do project building in Visual Studio (the Unity game engine is my primary development environment), but I will do my best to assist.
I believe that in RealSense SDK 2.0, Librealsense is linked in to a Visual Studio project via a program called CMake. The links below may be helpful in understanding this process.
https://github.com/zivsha/librealsense/tree/getting_started_example/examples/getting-started
https://github.com/IntelRealSense/librealsense/issues/2471
JAlli3
MartyG
Is your project linking to the RealSense library correctly now, please?
JAlli3
Yes it is. See my above post for the solution. Thanks again, I appreciate your response.
