I run the commands as the website: https://github.com/IntelRealSense/realsense_samples_ros/blob/kinetic-devel/realsense_ros_slam/README.md realsense_samples_ros/README.md at kinetic-devel · IntelRealSense/realsense_samples_ros · GitHub
$ cd catkin_ws
$ source devel/setup.bash
$ roslaunch realsense_ros_slam demo_slam.launch
And the terminal shows as following including two cases.
Case 1:
yuanlibin@yuanlibin:~/catkin_ws$ roslaunch realsense_ros_slam demo_slam.launch
... logging to /home/yuanlibin/.ros/log/ce3f41f2-63b1-11e8-9c51-1c1b0d61bf22/roslaunch-yuanlibin-2914.log
Checking log directory for disk usage. This may take awhile.
Press Ctrl-C to interrupt
Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://yuanlibin:43883/ http://yuanlibin:43883/
SUMMARYPARAMETERS
- /realsense_ros_camera/accel_optical_frame_id: camera_accel_opti...
- /realsense_ros_camera/color_fps: 30
- /realsense_ros_camera/color_height: 480
- /realsense_ros_camera/color_optical_frame_id: camera_rgb_optica...
- /realsense_ros_camera/color_width: 640
- /realsense_ros_camera/depth_fps: 30
- /realsense_ros_camera/depth_height: 240
- /realsense_ros_camera/depth_optical_frame_id: camera_depth_opti...
- /realsense_ros_camera/depth_width: 320
- /realsense_ros_camera/enable_color: False
- /realsense_ros_camera/enable_depth: True
- /realsense_ros_camera/enable_fisheye: True
- /realsense_ros_camera/fisheye_fps: 30
- /realsense_ros_camera/fisheye_height: 480
- /realsense_ros_camera/fisheye_optical_frame_id: camera_fisheye_op...
- /realsense_ros_camera/fisheye_width: 640
- /realsense_ros_camera/gyro_optical_frame_id: camera_gyro_optic...
- /realsense_ros_camera/ir2_optical_frame_id: camera_ir2_optica...
- /realsense_ros_camera/ir_optical_frame_id: camera_ir_optical...
- /realsense_ros_camera/serial_no:
- /realsense_ros_slam/doi_max: 3.0
- /realsense_ros_slam/doi_min: 0.3
- /realsense_ros_slam/hoi_max: 0.1
- /realsense_ros_slam/hoi_min: -0.5
- /realsense_ros_slam/load_occupancy_map:
- /realsense_ros_slam/load_relocalization_map:
- /realsense_ros_slam/map_resolution: 0.05
- /realsense_ros_slam/occupancyFilename: occupancy_1019.bin
- /realsense_ros_slam/publish_odometry: True
- /realsense_ros_slam/relocalizationFilename: relocalization_10...
- /realsense_ros_slam/resolution: 0.1
- /realsense_ros_slam/topic_camera_pose: camera_pose
- /realsense_ros_slam/topic_map: map
- /realsense_ros_slam/topic_odom: odom
- /realsense_ros_slam/topic_pose2d: pose2d
- /realsense_ros_slam/topic_reloc_pose: reloc_pose
- /realsense_ros_slam/topic_tracking_accuracy: tracking_accuracy
- /realsense_ros_slam/trajectoryFilename: trajectory_1019.ppm
- /rosdistro: kinetic
- /rosversion: 1.12.13
NODES
base_link_to_camera_link (tf2_ros/static_transform_publisher)
map_to_odom (tf2_ros/static_transform_publisher)
odom_to_base_link (tf2_ros/static_transform_publisher)
realsense_ros_camera (nodelet/nodelet)
realsense_ros_camera_manager (nodelet/nodelet)
realsense_ros_slam (nodelet/nodelet)
rviz_demo (rviz/rviz)auto-starting new master
process[master]: started with pid [2926]
ROS_MASTER_URI=http://localhost:11311/ http://localhost:11311setting /run_id to ce3f41f2-63b1-11e8-9c51-1c1b0d61bf22
process[rosout-1]: started with pid [2939]
started core service [/rosout]
process[realsense_ros_camera_manager-2]: started with pid [2957]
process[realsense_ros_camera-3]: started with pid [2958]
process[map_to_odom-4]: started with pid [2959]
process[base_link_to_camera_link-5]: started with pid [2967]
[ INFO] [1527647595.983569884]: Loading nodelet /realsense_ros_camera of type realsense_ros_camera/NodeletCamera to manager realsense_ros_camera_manager with the following remappings:
process[odom_to_base_link-6]: started with pid [2969]
process[rviz_demo-7]: started with pid [2982]
process[realsense_ros_slam-8]: started with pid [2995]
[ INFO] [1527647596.006325421]: waitForService: Service [/realsense_ros_camera_manager/load_nodelet] has not been advertised, waiting...
X...
It was difficult to tell what was happening from looking at the logs. The problems seem to start when this error occurs:
terminate called after throwing an instance of 'std::runtime_error' what(): Duration is out of dual 32-bit range
This can cause a 'No map received' error to occur in Rviz, like in this case:
https://github.com/ROBOTIS-GIT/turtlebot3/issues/83 No map error in RVIZ · Issue # 83 · ROBOTIS-GIT/turtlebot3 · GitHub
This error apparently occurs when a timestamp is out of sync (for example, when connecting two machines, and one is not in sync with the other).
MartyG
Thanks for your quick reply. I have tried the method from the link, however, it does not work.
In addition, my dual system includes Ubuntu 16.04 and Windows 10.
Libin
This question of dual systems is outside of my field of knowledge, unfortunately. I will link this conversation to McCool who is a SLAM and robotics expert who may have a better idea about what the problem with your project is. Good luck!
MartyG
Thank you very much. And there is a similar issue at this link: https://github.com/IntelRealSense/realsense_samples_ros/issues/14 SLAM Problem · Issue # 14 · IntelRealSense/realsense_samples_ros · GitHub
Libin
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
