Items with no label
3339 Discussions
Accessing a D415 via WiFi
DOliv12
Did someone here had some experience accessing the D415 (or other RealSense Camera) via WiFi ? Is the UpBoard the only (or maybe best...) way to go in a scenario in which i have to use 2 or more depth cameras working together ?
Thanks for any ideas, comments ...
MartyG
Two D415s on an Up Board should work, according to information provided by an Intel support agent in a recent discussion on this topic.
Up Board isn't your only option though for multi-camera setups. It should work with any computing device with an Intel or ARM processor chip that can have 2 or more cameras attached to it (whether directly to USB 3.x ports on the device or to a USB 3.x hub).
Regarding your wi-fi question ... it would not be practical to send camera data over wi-fi, as it requires some kind of cabling due to the large amount of camera data bandwidth that is sent through the cable. And alternative solution may be to use USB cable extension, such as the industrial-grade solutions provided by Newnex that can carry RealSense data up to 100 m.
https://www.youtube.com/watch?v=GLQgR1jT04M USB Extension for Intel RealSense D400 Series Camera - YouTube
MartyG
DOliv12
Hi MartyG
Much appreciated your clarifications ... and also for sending the link to the Aaeon UP board...
I will run my tests with 2 cameras currently using USB3 repeaters ... but i'm thinking on trying later on to run some processing in the edge (using the capabilities for doing that inside the UP Board maybe....). This would avoid having to force RGB and Depth streams over cables ...
Again, thank you for your prompt reply !
MartyG
Thanks David! If you are considering using an Up Board, you may also be interested in a recent discussion about using it with D415 and Windows 10 IoT Enterprise, the specialized Internet of Things version of Windows 10.
https://github.com/IntelRealSense/librealsense/issues/2296 d415 module support windows 10 iot ?? · Issue # 2296 · IntelRealSense/librealsense · GitHub
Hi David,
Accessing data from a D415 via WiFi is not possible, because there is too much data to transmit via wifi (especially when synchronizing multiple cameras).
If a cable longer than 2m is required and would be more practical for your project, we recommend using USB3 repeaters, and not extension cables (here is one we have tested):
https://centralcomputers.com/p-1130142-unitek-y-3005-usb30-aluminium-extension-cable-10unitek-y-3005-usb30-aluminium-extension-cable-10m33product.aspx
As far as computing boards go, Marty G. is right about being able to use any computing device with an Intel or ARM processing chip, so long as it has enough processing power.
For more information about multi camera synchronization using the RealSense cameras, visit the whitepapers here:
https://simplecore.intel.com/realsensehub/wp-content/uploads/sites/63/Multiple_Camera_WhitePaper04.pdf
Sahira
DOliv12
Hi Sahira !
Thanks for the recommendation...
And also for sending the link of your recommended USB3 Repeater...
And also for the Multi Camera white paper !
Thank you.
DOliv12
As a matter of fact... my intention was to use it with Ubuntu ...
But again, thanks for the advise Marty !
