Items with no label
3338 Discussions
Available attributes of frame metadata ( RealSense D415 )
均林
Dear Intel Support Team,
I want to get the exposure value when Auto Exposure is on, so I tried to call rs2_get_frame_metadata() with testing for attribute support :
if ( rs2_supports_frame_metadata(.., attribute,...) ){
val = rs2_get_frame_metadata(.., attribute,...)
However, It seems that there are only 3 attributes are supported :
"RS2_FRAME_METADATA_TIME_OF_ARRIVAL" ,
"RS2_FRAME_METADATA_BACKEND_TIMESTAMP",
"RS2_FRAME_METADATA_ACTUAL_FPS"
Will other attributes such as exposure value be supported in the future?
Is there any other way?
JY
MartyG
Instead of using frame metadata, you can get the exposure value with get_option, as described in the discussion linked to below, which suggests printing out exposure to a log with the instruction:
print(sensor.get_option(rs.option.exposure)
https://github.com/IntelRealSense/librealsense/issues/1624 auto_exposure problem · Issue # 1624 · IntelRealSense/librealsense · GitHub
均林
Hi MartyG,
In fact, I want to get the actual exposure value rather than the manual exposure value. (Just like what is mentioned in the discussion you offered)
Therefore, I enabled auto_exposure first waiting the camera to adjust to the proper exposure value, then I switched off auto_exposure and try to get the adjusted exposure.
MartyG
Thanks for the update! Do you need further assistance?
均林
Hi MartyG,
Thanks for your help.
It seems that the actual exposure attribute is not supported in D415 so I cannot query it.
I really hope more metadata attributes would be supported in the future.
MartyG
You can file a request for a particular feature to be added on the RealSense GitHub by going to the link below and clicking the 'New Issue' button to post a message.
https://github.com/IntelRealSense/librealsense/issues Issues · IntelRealSense/librealsense · GitHub
MPrat3
Using firmware version 5.10.3 I was successfully able to query my D415 (using the Python API, but you can re-derive the C++ one):
frames = pipeline.wait_for_frames()
depth_frame = frames.get_depth_frame()
actual_exposure = depth_frame.get_frame_metadata(rs.frame_metadata_value.actual_exposure)
MartyG
Thanks for sharing your solution, mprat!
均林
Thanks for your help, mprat.
After some additional steps that are specified in thehttps://github.com/IntelRealSense/librealsense/blob/master/doc/installation_windows.md installation guide, I can get the frame metadata of RGB & depth sensor !
However, according to issue https://github.com/IntelRealSense/librealsense/issues/2218 # 2218, the actual exposure metadata attribute for RGB sensor updates only with the "Auto-exposure" flag is "Off" and this is a HW limitation.
Therefore, it seems that the current actual exposure value of RGB sensor cannot be get.
