Items with no label
3338 Discussions
Calculating SR300 FOV
ewu12
Hi, all
I am beginner and want to calculate SR300 FOV and work distance .
At the SR300 datasheet , show out the VFOV(41.5)& HFOV(68) angle.
i don't how to translate FOV area mm/unit and work distance(W.D.)
thanks.
Edison.
Pablo_M_Intel
Hi Edsion,
You might want to check this information as well. It was taken from here https://github.com/IntelRealSense/librealsense/blob/master/doc/camera_specs.md https://github.com/IntelRealSense/librealsense/blob/master/doc/camera_specs.md.
---------R200F300 SR300 Indoor Range0.7m – 3.5m0.2m – 1.0m0.2m – 1.5mOutdoor Range10mNANAField of View56°x43°68°-54°68°-54°
Hopefully this information will help you.
Kind regards,
Pablo M.
MartyG
This subject of calculating camera variables manually has come up a couple of times before. This discussion may be of use to you.
Pablo_M_Intel
Hi Edsion,
Kind regards,
Pablo M.
