Items with no label
3340 Discussions
Camera Realsense 415, save file bag in LabVIEW
mzaid1
Hi, i need to save file bag trought LabVIEW.
I tried to use the ROS package for LabVIEW but it is more focused on the comunication between ROS device and another Pc.
How i can save bag files?
thank you
MartyG
Apologies for the delay in responding. The 'Frame Metadata' documentation of the RealSense SDK provides details of how to access metadata, including the list of functions that are encapsulated within rs2_frame_metadata_value
https://github.com/IntelRealSense/librealsense/blob/master/doc/frame_metadata.md
MartyG
If you have a Windows 10 PC, the RealSense SDK has a LabVIEW wrapper that wraps most of the core functions of the realsense2.dll into a VI-library. Although the documentation for the LabVIEW wrapper does not provide an example program for saving a bag, I would speculate that it should be possible to write one if the wrapper links into most of the camera library file's core functions.
https://github.com/IntelRealSense/librealsense/tree/master/wrappers/labview
mzaid1
Thank you for your answer MartyG
Yes i have a windows 10PC and I try to use the function
rs2_metadata_type rs2_get_frame_metadata(const rs2_frame * frame,rs2_frame_metadata_value frame_metadata,rs2_error ** error )
This function recall the function rs2_frame_metadata_value that is not present in the library functions
how i can obtain the metadata value?
thank you
MartyG
