Items with no label
3341 Discussions
Realsense D435 not detected when restarted on win7?
XLong5
My platform is an IPC with Windows7 Embeded Standard. Every time I restart the machine, realsense viewer tells that no device detected. It only works if I replug the camera.
MartyG
I tracked down some advice given by an Intel support team member about a case where the fail-after-restart problem was occurring with Intel Atom based hardware.
https://github.com/IntelRealSense/librealsense/issues/1615#issuecomment-435459519
MartyG
Are you using the special Windows 7 version of the RealSense SDK, please?
XLong5
Thank you so much for your reply! My platform is Intel Atom with Window7, and I can only get one version of Realsense SDK for Win7, which I think it's not a special version.
MartyG
I just mean it is special because it is more common for the Windows 10 version to be used. :)
The Intel Atom processor is not likely to be the cause of your problems, since the 400 Series cameras can work with any Intel or ARM processor.
I have heard of this problem before - the camera works fine when the computer is first started but stops being detected after a restart. Is that correct please?
Here is a link to a case relating to the D415 model where these symptoms were occurring with a NUC PC. It may give you some ideas about things to check on your own settings.
https://github.com/IntelRealSense/librealsense/issues/1283
MartyG
XLong5
Thank you for your help! I will try Win 10 and Ubuntu, maybe it works.
