Items with no label
3341 Discussions
Camera intrinsics mismatch
JMois
I've found that when I use the Calibration interface to query camera intrinsics (focal length and principal point), I get a different result than when I use the Device interface.
For example, with my SR300, using Intel::RealSense::Calibration:
calibration->QueryStreamProjectionParameters(StreamType::STREAM_TYPE_DEPTH, &depthCalib, &depthTransform);
reports focal length of {x=475.89, y=475.89} and principal point of {x=313.28, y = 240.76}.
But when I using Intel::RealSense::Capture::Device:
auto depthFocalLength = device->QueryDepthFocalLength();
auto depthPrincipalPoint = device->QueryDepthPrincipalPoint();
I get focal length of {x=463.88, y=463.88} and principal point of {x=320.00, y=240.00}.
Why do these two interfaces report different results? Which is accurate?
Hello JonathanMoisantThompson,
Thanks for reaching out!
I'd like to share the links for the documentation of QueryStreamProjectionParameters, QueryDepthFocalLength, QueryDepthPrincipalPoint:
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?querystreamprojectionparameters_pxccalibration.html
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?querydepthfocallength_device_pxccapture.html
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?querydepthprincipalpoint_device_pxccapture.html
If you read the description of the QueryStreamProjectionParameters function, it is mentioned that it returns the calibration and transformation parameters of the specified stream type.
Meanwhile on the documentation of QueryDepthFocalLength and QueryDepthPrincipalPoint it is mentioned that they return their respective parameters values but they also make an important note, the property value is the model fixed value, and not the device instance calibrated value hence the difference in the outputs.
I hope this helps.
-Peter.
Do you have any updates about this?
-Peter.
