Items with no label
3338 Discusiones
Can I/how do I record video footage using the Intel Euclid and save it on my PC?
ODean
Principiante
1.759 Vistas
I am looking to record a short (10 second) piece of video footage so I can use it for an object detection research project. What is the procedure to record and save videos using the Intel Euclid?
0 kudos
1 Solución
MartyG
Colaborador Distinguido III
525 Vistas
All of the Intel Euclid development team members that I know of have left Intel for other companies since Euclid's release, so answering some of the more technical questions about Euclid can be difficult. I will try to provide you with some guidance though based on my own knowledge of it.
Euclid has the ability to set up 'Scenarios' to run a collection of program 'nodes' in a certain way in order to produce a desired outcome. It is essentially a way to create a program without having to write all the code yourself. Below is a link to a tutorial video for creating new Scenarios for Euclid.
https://vimeo.com/218350489
For example, Euclid has a pre-made 'Camera' node for running the cameras. This node is referenced in a pre-made Scenario program called 'Cameras' that runs two nodes, 'Camera' and 'Depth Transcode'. With this Scenario, you can view the cameras by navigating to Euclid's "Monitor" tab and turning the cameras on.
The principles of how Euclid uses ROS nodes is described on page 9 of the Euclid operating manual.
https://click.intel.com/media/productid2100_10052017/euclid-operating-guide-final.pdf
Whilst you may be able to view the camera streams using a Scenario, the next challenge to overcome may be to record those streams, if the Camera node does not already provide the ability to do so. At this point I can only offer speculation as I have not used Euclid directly. If I were approaching this problem myself though, I would try editing the pre-made 'Cameras' Scenario to add a ROS node package that can perform camera recording. You can research ROS packages for doing this recording task by googling for 'ros node record camera'
I apologize that I could not give more definitive, certain guidance than this. Good luck!
Ver la solución en mensaje original publicado
1 Responder
MartyG
526 Vistas
Responder
