I would for example to stream at 1280x704... I am attempting to not have to resize an image but fit what I am doing exactly in a frame.
Do I only get to choose from the pre-populate list?
I am using Python and I get the error "Couldn't resolve requests" on the pipline.start(config) line
I also get this error if I try to run at 1920x1080. It will stream fine at 1280x720. In all cases I am using 6 fps.
it runs fine at 640x480 as well
Hi pault587,
Thank you for your interest in the Intel RealSense D415 camera.
The supported resolutions for the depth and RGB streams are listed in Table 4-2, on page 53 in the user manual:
https://www.intel.com/content/dam/support/us/en/documents/emerging-technologies/intel-realsense-technology/Intel-RealSense-D400-Series-Datasheet.pdf
You can also see how many fps are supported for each resolution.
Let me know if you have further questions.
Alexandra
Hi pault587,
Alexandra
