I downloaded the DFU or what I believe is the device driver ? to my Raspberry Pi Linux OS device , I see the zip file in downloads, and when I plug in the D415 via USB and attempt to run the peripheral D415 camera I get error message "DeviceOpen using default: no devices found " , I am attempting to replace old PrimeSense camera with new Intel D415 camera to capture 3D . Are there additional steps I need to be walked through ? Please help. Thanks Chris
Intel have a guide to installing Librealsense on Raspberry Pi 3 Model B.
https://github.com/IntelRealSense/librealsense/blob/master/doc/RaspberryPi3.md librealsense/RaspberryPi3.md at master · IntelRealSense/librealsense · GitHub
If you do not wish to use Ubuntu MATE as your OS as the guide suggests, there are also instructions for installing Librealsense on any flavor of Linux.
https://github.com/IntelRealSense/librealsense/issues/1132# issuecomment-363572666 Linux support · Issue # 1132 · IntelRealSense/librealsense · GitHub
still have not found solution ??
Have you followed the instructions to update Ubuntu and its kernel and then install the RealSense SDK 2.0, please?
https://github.com/IntelRealSense/librealsense/blob/development/doc/installation.md librealsense/installation.md at development · IntelRealSense/librealsense · GitHub
