Items with no label
3340 Discussions
Cannot connect to Euclid via browser
Initially I could connect to Euclid via my browser after connecting to the Euclid hotspot. Yesterday I connected Euclid to my monitor and booted into Ubuntu desktop and poked around the OS (did not make any changes to the system). This morning when I boot up the Euclid I do not get the chimes sound indicating Euclid is ready. However I can connect to the Euclid hotspot and browse to 10.42.0.1. However all I see is the spinner and loading Scenarios...
Did going into the Ubuntu desktop break something and if so how do I fix it. If I need to reset/reinstall is it possible to download an ISO of the original software image or is there a recovery procedure.
Amit_M_Intel
Connecting the device via HDMI isn't breaking it.
does the problem persists after restart?
Amit
(Intel)
Yes the issue persists after restarting, I am no longer getting the startup sound when the Euclid boots up. Playing around some more I am able to get to the page on the web app that shows memory and CPU utilization and it looks like there is no data being sent from the device for the page (the gauges don't move anymore). I'm guessing that some other service needed by the web app is not starting up at boot time. Unfortunately I have no idea what is supposed to be starting up or why it's not starting.
If you can point me in the direction of what logs or what services need to be running that would be a great start. Unfortunately there is not a huge amount of documentation on the device available right now.
Finally, should there be a need for me to factory reset the device (now or in the future) how would I go about doing that and getting all the necessary software.
Amit_M_Intel
Please start a terminal and run:
sudo services oobe-init restart-oobe
and share the output.
for the image, we will publish soon.
This is the combined output of stdout and stderr. I added bold to illustrate a couple of errors that seem to point to a malformed url.
The line 'Couldn't find an AF_INET address for [http]' continues to be reported on stderr forever until I kill off the process.
Thanks for the help.
Ian
sudo service oobe-init restart-oobe
Stopping ..
Error: ERROR: Unable to communicate with master!
roscore: no process found
rosmaster: no process found
Stoping startup
Stopping service: /intel/euclid/oobe-services/startup_services/S2WebServer/stop.sh
Stopping service: /intel/euclid/oobe-services/startup_services/S6FeedbackServer/stop.sh
Error stopping: sigkill to standalone_nodelet
Done stopping service
Stoping monitor
Stopping service: /intel/euclid/oobe-services/monitor_services/S0ConnectionMonitor/stop.sh
Running startup
-I- Running startup scripts
-I- running service: /intel/euclid/oobe-services/startup_services/S0Init/init.sh
Startup - S0 Init running!
-I- running service: /intel/euclid/oobe-services/startup_services/S1Network/init.sh
-I- running service: /intel/euclid/oobe-services/startup_services/S2WebServer/init.sh
-I- running service: /intel/euclid/oobe-services/startup_services/S6FeedbackServer/init.sh
-I- Done running startup scripts
Running monitor scripts
-I- Running Mon scripts
-I- running service: /intel/euclid/oobe-services/monitor_services/S0ConnectionMonitor/init.sh
-I- Done running monitor scripts
Running oobe
-I- running OOBE scripts
-I- running service: /intel/euclid/oobe-services/ros_services/S1ROS/init.sh
[31minvalid master URI: http://http://localhost:11311:11311/ [0m
[31mThe traceback for the exception was written to the log file [0m
-I- running service: /intel/euclid/oobe-services/ros_services/S2ConfigModule/init.sh
-I- running service: /intel/euclid/oobe-services/ros_services/S3ROSBridge/init.sh
the rosdep view is empty: call 'sudo rosdep init' and 'rosdep update'
-I- running service: /intel/euclid/oobe-services/ros_services/S4WebVideoServer/init.sh
[31m[ERROR] [1491068292.926881316]: [registerPublisher] Failed to contact master at [http:0]. Retrying... [0m
-I- Done running OOBE scripts
Majd_S_Intel
I see what's your problem, please open terminal and edit the file /intel/euclid/config/settings.ini
edit the ROS_MASTER_URI, and change it to http://localhost:11311
and restart the service again (or Euclid) it should work
Best,
Majd (Intel)
Thanks Majd, that fixed the issue. I'm back up and running again. Not sure what caused the uri to get changed but glad to see the fix was easy.
Thanks again,
Ian
ARoma13
When I run the restart oobe script, it hangs up at this line:
ARoma13
I did this
$ export ROS_HOSTNAME=localhost
$ export ROS_MASTER_URI= http://localhost:11311
And restarted, and it started working.
