Items with no label
3341 Discussions
Compiling librealsense-persontracking for TX2
RLee36
librealsense-persontracking is not available on the arm repo for TX2.
How might I be able to obtain the source code for cross-compiling? Or compiling an arm version for that matter?
MartyG
I believe that the package to look for to get source could would be librealsense-persontracking-dev, the 'dev' part indicating that it is source code rather than a built binary. I could not find a way to obtain this file other than installing the RealSense SDK For Linux though.
https://software.intel.com/sites/products/realsense/intro/getting_started.html Introduction to Intel® RealSense™ SDK for Linux: Getting Started
In that SDK for the RealSense ZR300 camera, the librealsense-persontracking-dev file is installed along with the object rcognition and SLAM files using this instruction:
$ sudo apt install librealsense-object-recognition-dev librealsense-persontracking-dev librealsense-slam-dev
RLee36
Hey, could you advice on how I should have the arm version for that package compiled? From getting the source code to compiling (instructions) included. I'd be fine if you would even point me to a tutorial elsewhere.
MartyG
I do not personally have experience of compiling Librealsense with ARM but others have done it successfully, including getting a Jetson TX1 working with Librealsense. Someone made a forked version of the old Librealsense with ARM support for their TX1, so that may be a good place for you to research.
https://github.com/Maghoumi/librealsense GitHub - Maghoumi/librealsense: librealsense with ARM support
RLee36
Thanks! I'll reach out for advice
