Items with no label
3341 Discussions
Get infrared stream using C examples for D415
WArro
Hi all,
I am trying out the C examples (rs-depth) to get to get the depth and color streams using this:
//configurations:
rs2_config_enable_stream(config, RS2_STREAM_DEPTH, -1, WIDTH, HEIGHT, RS2_FORMAT_Z16, FPS, &e);
check_error(e);
rs2_config_enable_stream(config, RS2_STREAM_COLOR, -1, WIDTH, HEIGHT, RS2_FORMAT_RGB8, FPS, &e);
check_error(e);
//extracting depth and color:
if (rs2_is_frame_extendable_to(frame, RS2_EXTENSION_DEPTH_FRAME, &e) == 1) {
//this is the depth frames
} else{
//this is the color frames
My issue now is I cannot get the Infrared streams because I cannot see something like RS2_EXTENSION_DEPTH_FRAME for the infrared stream.
Any inputs are very much appreciated. Thanks.
MartyG
A couple of SDK 2.0 versions ago, an instruction was added to make it easier to get infrared frames from an rs2:frameset.
rs2::frameset::get_infrared_frame()
See line 691 of the script linked to below for an example use:
https://github.com/IntelRealSense/librealsense/blob/master/include/librealsense2/hpp/rs_frame.hpp# L691 librealsense/rs_frame.hpp at master · IntelRealSense/librealsense · GitHub
