Hello community! My first post here so please be gentle...
I cannot find any documentation or explanation of the "Advanced Mode" settings for the D415 camera. Does this exist somewhere?
In particular, I need to remove (or at least significantly reduce) speckles of "unknown depth" in the depth-stream returned from the camera. It would be nice to achieve this by tweaking settings but I could also implement some post-procesing - any hints in this direction would be most welcome!
- Bjarne
链接已复制
Jesus,
I upgraded to 2.9.1 (built from sources on Ubuntu 16.04 with the 4.10.0-42 kernel) in order to try this again. Please see the following screenshot
The JSON-file is attached. (You might want to ensure you have not checked the "Don`t show this error again" checkbox in the alert... )
- Bjarne
BjarneG,
Thank you for providing the JSON file. However, I was able to load that file without an error. I played the RAU parameters in the viewer and saved and loaded the JSON files several times without error. In order to cause an error, I had to open the JSON file, edit it manually, and set any parameter to an invalid value. Is this what you are finding?
Jesus
