Items with no label
3341 Discussions
D415-why the roof is seen in depth image on the left side of the wall?
VT000
The distance for visualization was set between 80-100cm, the camera was 90cm from the wall. The high accuracy preset was set, also the edge filtering was on (according to the Intel's whitepaper). The roof is about 6-7 meters far from the camera. What is wrong here? Is it possible to separate correctly the wall from the window and the background with D415 (like I have separated the shape from the wall in the image)?
Thank you.
Kind regards
MartyG
This question has been responded to on the GitHub. by the Chief Technical Officer (CTO) of the RealSense Group. Thank you.
https://github.com/IntelRealSense/librealsense/issues/3961
MartyG
CaitlinColema
Hi. I need help designing my home. I'm doing a project for the first time here, so I don't know much. I can't fold the pieces of tile synchronously and fasten them at an angle. Maybe there is an instruction on how to design the roof correctly?
