Items with no label
3341 Discussions
D435 Getting Started under Linux?
RTasa
Is there a getting started under Linux for this camera?
I have the Jetson TX2 and wanted to get the D435 and examples running.
I also have a laptop with the unbuntu installed.
MartyG
You can download the RealSense SDK 2.0 from this link:
https://github.com/IntelRealSense/librealsense/releases/ Releases · IntelRealSense/librealsense · GitHub
After that though, the instructions get somewhat contradictory. The download page says that SDK 2.0 supports Ubuntu 16.04 LTS, but the installation doc linked to from that page is orientated around Debian Linux.
My recommendation would be to look at the instructions page for compiling for Ubuntu from the source code version of the SDK.
https://github.com/IntelRealSense/librealsense/blob/development/doc/installation.md librealsense/installation.md at development · IntelRealSense/librealsense · GitHub
RHert
Realsense D435: FW 5.08.15.0
Platform: Jetson TX1
Ubuntu 16.04
Tendak USB 3.0 powered Hub
I successfully compiled the source code based on the instructions.
Here is what I see:
Bus 002 Device 007: ID 8086:0b07 Intel Corp.
Bus 002 Device 003: ID 045b:0210 Hitachi, Ltd
Bus 002 Device 002: ID 0955:09ff NVidia Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 045b:0209 Hitachi, Ltd
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
nvidia@tegra-ubuntu:~$ lsusb -t
/: Bus 02.Port 1: Dev 1, class="root_hub", Driver=xhci-tegra/4p, 5000M
|__ Port 1: Dev 2, If 0, class="Vendor" Specific Class, Driver=r8152, 5000M
|__ Port 2: Dev 3, If 0, class="Hub", Driver=hub/4p, 5000M
|__ Port 1: Dev 7, If 0, class="Video", Driver=uvcvideo, 5000M
|__ Port 1: Dev 7, If 1, class="Video", Driver=uvcvideo, 5000M
|__ Port 1: Dev 7, If 2, class="Video", Driver=uvcvideo, 5000M
|__ Port 1: Dev 7, If 3, class="Video", Driver=uvcvideo, 5000M
|__ Port 1: Dev 7, If 4, class="Video", Driver=uvcvideo, 5000M
/: Bus 01.Port 1: Dev 1, class="root_hub", Driver=xhci-tegra/5p, 480M
|__ Port 3: Dev 2, If 0, class="Hub", Driver=hub/4p, 480M
Which would indicate that the camera is showing up correctly as a USB 3.0 device.
When I execute ./cpp-config-ui . I get the following:
No device found. Is it plugged in?
X Error of failed request: GLXBadDrawable
Major opcode of failed request: 154 (GLX)
Minor opcode of failed request: 11 (X_GLXSwapBuffers)
Serial number of failed request: 3990
Current serial number in output stream: 3992
Have you seen this error before with 200 or 300 series of Realsense cameras?
MartyG
I haven't seen those errors before, unfortunately.
Did you compile the SDK from the latest 2.9.1 build? That build is marked as 'pre-release' in the release notes because it has some stability issues that are being worked on. The most recent stable build is 2.9.0.
https://github.com/IntelRealSense/librealsense/releases/tag/v2.9.0 Release Intel® RealSense™ SDK 2.0 (build 2.9.0) · IntelRealSense/librealsense · GitHub
