Items with no label
3341 Discussions
Euclid Handheld Mapping
CMock
Hello community,
has somebody tried to use Euclid as handheld mapping device ?
I'd like to create indoor and outdoor maps from some environments.
Is rtabmap usefull for creating maps or is it possible to use builtin nodes ?
Thanks for feedback and sugguestions ;-)
Cheers
Chrimo
Hello Chrimo,
Thanks for contacting the Intel RealSense community.
I have been researching on the records about the usage of the rtabmap for mapping and I found this article:
http://www.euclidcommunity.intel.com/static/tutorials/pdf/rtabmap.pdf
It is a custom implementation on a robot (which is basically the same as a handheld project) and this application actually works great. Please check this article it could be a great guidance for you.
Juan N.
MartyG
I was reminded of this RealSense room mapping demo by Intel from 2015.
https://m.youtube.com/watch?v=Vpa8vKsapFk https://m.youtube.com/watch?v=Vpa8vKsapFk
Edit: I thought I'd add a little background info. In early 2016 there was a RealSense device called the RealSense Smartphone Developer Kit, which was an Android-based smartphone with a RealSense ZR300 camera in. It almost made it to public release and there are some preview units floating around I believe, but Intel cancelled it in summer 2016 before it went on public sale because the RealSense strategy shifted away from mobile. Its web page still survives though.
https://software.intel.com/en-us/blogs/2016/02/22/introducing-intel-realsense-smartphone-developer-kit Archived - Introducing Intel® RealSense™ Smartphone Developer Kit | Intel® Software
Google have also now killed Google Project Tango recently, replacing it with ARCore.
With the release of RealSense SDK 2,0 though, working with Android is becoming a possibility again.
https://github.com/IntelRealSense/librealsense/blob/development/doc/android/Android.md librealsense/Android.md at development · IntelRealSense/librealsense · GitHub
CMock
Hi all,
I've already compiled rtabmap and rtabmap_ros from sources, but I'm fighting with core dumps, while testing.
Looks like this:
My question: creates RealsenseSLAM useful maps which can be visualized with builtin tools ?
Thanks for all your feedback and suggestions.
Cheers
Chrimo
Meitav_K_Intel
Hi Chrimo,
I have to say that from my experience, RTABmap performs poorly when used handheld (tracking is frequently lost and fails to recover).
However, I also made a guide for ORBSlam, which you can find on our community webpage here: http://www.euclidcommunity.intel.com/ Intel® Euclid™ Community
While it creates a less dense map, it works very well (with implemented bundle adjustment too), and you can use it to create large scale maps.
As for Realsense SLAM, the code that was adapted to ROS and run on Euclid does not normally give you the map, but you can use Jay's fork from here to make it show up:
Also please let me know if you encountered the core dumps after following the instructions in the document for RTAB. It should work (I've installed it myself quite a few times).
Hope this helps and let us know what you discover!
Cheers,
Meitav
Intel Euclid Development Team
