Items with no label
3341 Discussions
DE0-CV Board - Clock Manager IP module for 200 MHz frequency
anm
this is my first interaction with Intel FPGAs and Intel's Forum. :)
I have a DE0-CV Board with a Cyclone V on it (CycloneV 5CEBA4F23C7N ).
The Board has 4x50 Mhz Buffered Clocks.
I want to generate a frequency of 200MHz for my design.
 Is there an IP module (like a Digital Clock Manager) provided, that will do this conversion and output a clock signal of 200 MHz for my design?
Is there documentation containing such IP modules (Clock Managers, Clock Buffers, etc.) for Cyclone V FPGAs?
I am using Quartus Pro v19.4.
Thank you in advance for your response and time.
Kind regards,
anm
anm
Update:
I found this IP at the Documentation Center:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/altera_pll.pdf
Is this the right IP core to use, in order to create the 200MHz frequency?
The board also has 4 Fractional PLLs. Will the Quartus use the above IP and implement it on one of the Fractional PLLs in order to create the 20MHz clock frequency?
Kind regards,
anm
anm
UP
Is anyone monitoring these discussions?
