Items with no label
3341 Discussions
Dell optiplex 9020 All In One cpu upgrade
icc89100
Dell optiplex 9020 All In One cpu upgrade CPU Intel(R) Core(TM) i5-4570S CPU @ 2.90GHz (2.90 GHz) ​
​je viens de faire mise a jour en migration de Windows 10 sur Windows 11 passer sans problème , je viens de faire la mise a jour en upgrade de la ram 16 go je souhaite booster mon upgrade Carte mère Modèle Dell 0WPG9H cpu ou le dernier possesseur Maximum prise en charge pour se model I7 merci avance​unnamed.png
n_scott_pearson
There are certainly a number of 4th gen Core processors that could be used in this configuration: 4th gen Intel Core i7 processors. I would guess the Intel® Core™ i7-4770S Processor or the Intel® Core™ i7-4790S Processor would be the best matches.
My cautionary notes:
  • You need to be careful to utilize a processor that is supported by your PC's BIOS. Dell should have some sort of documentation or page reference that provides this information.
  • You need to be careful to utilize a processor that is supported by your PC's cooling solution. I do not know whether Dell had separate cooling solutions for the i5 and i7 processors.
  • If it's ok, you will need to reinstall the cooling solution onto this replacement processor. This will require the cleaning of the contact surface on the cooling unit and the application of fresh TIM (Thermal Interface material, heatsink paste). I recommend Arctic Cooling's MX-4 or MX-6.
Hope this helps,
