Items with no label
3341 Discussions
Microphone problems
Jhosty
I have a problem with the microphone, the computer is new and the microphone does not work, I try to fix the microphone but when I go into its settings to test it, it always keeps its green stripes at maximum and it does not have any variation and they do not detect the sound when speaking and the microphone does not work at any time.
VonM_Intel
Hi, Jhosty.
Thank you for posting in our Community.
Please share the exact make and model of your device so I can find the correct drivers, as I suspect the issue might be related to the audio driver. Alternatively, providing the SSU logs from your device would be helpful. These logs can give detailed information, such as the OS build number and any potential errors, which could assist in resolving the issue. Additionally, let's check some basic things with your device to help isolate the problem. Have you ensured the microphone is properly connected to the correct port on your computer? If it's a USB microphone, try using a different USB port. Also, have you tried using a different microphone to isolate the issue?
Have a nice day!
Von M.
VonM_Intel
Hi, Jhosty.
Von M.
VonM_Intel
Hello, Jhosty.
I have not heard back from you, I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
Hagos
similar issue
my system information is attached scanned with intel tool
