Items with no label
3338 Discussions
Disparity error on Arria VGZ Custom PHY
PPerd2
Hello.
I trying to transfer data between two Arria VGZ with Custom PHY.
I use 2.5 Gbps preset, i.e. Standard PCS on gige mode with word aligner and rate match fifo (settings attached).
Between packages I pass the IDLE special code group - {9'h050,9'h1BC}. At the beginning of the package - 9'h1FB. At the end of the package - 9'h1FD.
Depending on the length of the package I add Carrier_Extend - 9'h1F7 or 9'h1F7,9'h1F7.
rx_syncstatus undicates that the synchronization is acquired. But as a result, there are disparity errors at the reception (Attached a signal to transmit and receive).
Project has no slack in TimeQuest.
Maybe I missed something when setting up Custom PHY or forming a frame?
Thank you for any help.
