Items with no label
3338 Discussions
[ERROR] [1498861545.467843804]: imu info missed
SMish7
I have recorded a bag file while running the camera scenario on Euclid's web interface and I have downloaded the highlevel slam code from github (the package realsense_sp) to my PC. When I play this bag file and launch the file named sp.launch from realsense_sp folder in my PC, the following error occurs:
"[ERROR] [1498861545.467843804]: imu info missed"
I don't get it and I am not able to find a solution. The imu data is published over the topic camera/imu/data_raw from the bag file and is not empty because when I do a rostopic echo for this topic, I see numbers on my screen. Still, I get this error. Any explanation?
S.
MSrou2
The realaense slam uses a service call to the camera in order to get the imu calibration data.. Thats why it fails with the rosbag..
SMish7
Is there any way to make it work with the bag file?
Amit_M_Intel
Only solution I can think of is to change the ros wrapping and to send it as a message.
you will need to change the camera node and the slam node.
Hi SubMarIn,
We are wondering if the suggestion provided by Amitmoran worked.
We will be waiting for your reply.
Leonardo R.
SMish7
I haven't tried it yet. Will let you know if I try it.
Hi SubMarIn,
It is fine, we will wait. Please let us know when you have updates.
Have a nice day.
Leonardo R.
