Items with no label
3341 Discussions
Error Playing Sample files
KT
I have recently got a R200. I carried out the following installations post the camera was detected by windows,
1. intel_rs_sdk_offline_package_r_6.0.21.6598 (SDK)
2. intel_rs_dcm_r200_2.0.3.39488 (RCM)
Post the installation I tried running some of the samples which worked(from Common Samples) but when I tried running R200 Samples I was not able to run even a single demo.
Even tried running the Unity sample which kept giving me error in DepthFusion.cs file.
Are there any specific things that are required to be installed or setting to be done to make this work ?
Any help would be appreciated.
OS: Windows 10 Home 64-bit
Unity: 5.4.1.f1
Processor: Intel i7 4850
RAM : 16GB
jb455
Valued Contributor II
The SDK and DCM you've installed are really old - is there a reason for that? You can get the latest from here: https://downloadcenter.intel.com/download/25044/Intel-RealSense-Depth-Camera-Manager Download Intel® RealSense™ Depth Camera Manager, https://software.intel.com/en-us/articles/previous-intel-realsense-install Previous Intel® RealSense™ Install Software | Intel® Software [the most recent SDK doesn't support the R200 so get 2016R2]
Also you'll need to restart your PC after installing the SDK for the Path variable to be set.
Hello cgydev,
Thanks for reaching out!
I noticed that you are using an outdated version of the SDK and DCM. So, my first suggestion is that you use the latest versions of each available to the R200, you can find them here:
DCM:
SDK:
http://registrationcenter-download.intel.com/akdlm/irc_nas/vcp/9078/intel_rs_sdk_offline_package_10.0.26.0396.exe
Uninstall the previous versions, install them both, try again and let me know how it goes.
-Peter.
Hello cgydev,
Do you have any updates about this?
-Peter.
