Items with no label
3341 Discussions
RealSense detection finger in table top for Unity
JJose26
Hi, I've got a project with a projector mounted in the ceiling and a round table( 6 meters between). How many maximum distance can i put the sensor over the round table?
Can i detect fingers over the table? but no air gesture, only 1 cm over the table maximum detection.
Can my Unity project detect the finger touch with RealSense?
JM
Hello Jose_M,
Thanks for reaching out!
What camera are you using? The camera with the biggest detection range is the R200 and it is up to 300 cm for hand Blob Segmentation and 500 cm for Person Tracking, as you can see in https://software.intel.com/en-us/articles/intel-realsense-data-ranges.
So, in this case, 6 m would exceed the maximum range for hand tracking of any of the cameras, which in this case would be 300 cm. My best suggestion in this case is that you check the document I shared above and check your camera's maximum range for hand tracking and place your camera a little bit under that limit.
Unity is still supported on the latest version of the SDK, so, you should indeed be able to detect gestures with Unity. You can get more information about the SDK in https://software.intel.com/sites/landingpage/realsense/camera-sdk/v2016r3/documentation/html/index.html?doc_devguide_introduction.html.
I hope this helps.
-Peter.
Hello Jose_M,
I hope this helps.
-Peter.
