Items with no label
3339 Discussions
¿Es posible instalar un SSD en una Tarjeta Madre Intel DH61CR?
AMeji10
Queria saber si es posible instalar un ssd en este modelo y de ser así cual tipo seria y de que capacidad.
Pd. Tambien quiero instalar una tarjeta gráfica. Pero no se hasta cual sea compatible
n_scott_pearson
There is no support in the DH61CR BIOS for NVMe SSDs. You can connect only 2.5" SATA III SSDs. They come in sizes from 16GB all the way up to 4TB. I recommend that you get one that is at least in the 500GB range.
The 500GB range starts at US$60. The 1TB range starts at US$90. The 2TB range starts at US$200. The 4TB range starts at a hefty US$550.
Hope this helps,
....S
Djmetelex
Hi Scott, but there is a PCI-E x16 NVME Adapter in the market and some x1/x4 too!! There is no chance to use them to boot with M.2 NVME cards? Boot as Boot Add-in Cards?? Thanks!
