Hi!
As the title say, is there a way to Generate a PCD/PLY containing normal x,y,z and curvature from my D415/D435 cameras.
I need it to register them with Open3D.
Thanks!
Could you provide more details please about what you consider to be 'normal'. Do you mean raw data without any distortion models such as Brown-Conrady applied? Thanks!
Hi!
# My PCD header
# .PCD v0.7 - Point Cloud Data file format
VERSION 0.7
FIELDS x y z rgb
SIZE 4 4 4 4
TYPE F F F U
COUNT 1 1 1 1
WIDTH 1280
HEIGHT 720
VIEWPOINT 0 0 0 1 0 0 0
POINTS 921600
DATA binary
# What I need
VERSION 0.7
FIELDS x y z rgb normal_x normal_y normal_z curvature
SIZE 4 4 4 4 4 4 4 4
TYPE F F F F F F F F
COUNT 1 1 1 1 1 1 1 1
WIDTH 198835
HEIGHT 1
POINTS 198835
DATA binary
Whilst I couldn't find an example for the 400 Series that used normal XYZ with PCL, I did find one for earlier RealSense cameras in Librealsense 1 (the predecessor of the current SDK 2.0 / Librealsense2). The calculations may be adaptable for the 400 Series.
https://joshmcculloch.nz/# !realsense https://joshmcculloch.nz/# !realsense
Most of the normals code starts in the section headed 'Cylinder fitting' about three-quarters down the page.
![](/skins/images/BC9A7A3465121B56B278007F4EE8899F/responsive_peak/images/icon_anonymous_message.png)
