Items with no label
Graphics bugs
FSout3
recently some graphic bugs have appeared on my computer, i have an intel i3 2100, with an intel hd graphics 2000, my pc was formatted due to the problem, but even so it persisted, it only happens within games, i'm desperate for solutions nothing I do it right, I've updated the graphics, over a thousand times, I tried to uninstall and install again, unfortunately nothing works, I need urgent help, I contacted the game and everything indicates that it is the graphic.
n_scott_pearson
Your computer is 9+ years old. I hate to say it, but there is no solution that doesn't involve money. Your choices are to add a graphics card (if that's even possible) or to simply replace this system with something more modern. Adding a graphics card (if even possible) is, IMHO, throwing away good money. Replacing this system is your best bet.
Sorry, reality bites,
n_scott_pearson
Another thought (why is it you always come up with these right after you press "Answer"?) - this may be the result of memory glitches. You could try borrowing some memory from a friend or repair shop to check this. The problem is that it could also be the motherboard failing or the processor failing.
Stay safe during this investigation. COVID-19 is not fun.
AlHill
@FSout3​ The reality of the situation is that you need to upgrade to a new system. If you are W8.1 or Windows 10, there is no way you could be updating the driver as you say. You are using the Microsoft GENERIC driver, which lacks features and performance. As time moves on, your problem will only get worse. There is no fix, there is no new driver, there is no support.
Doc
