Items with no label
3341 Discussions
intel board dx58so with post code 95
FGABR5
Boot stays for 4 - 5 minutes with a screen showing post code 95. After that the system starts normally.
AlHill
Try a different keyboard.
95 is "Instructing keyboard controller to run Self Test (PS2 only)"
Also, what is your bios rev?
Doc
FGABR5
I´ll try a different Keyboard. DX58SO – BIOS: BIOS Manufacturer: Insyde Software BIOS Date: 04/14/2010 BIOS Version: SOX5810J.86A.5200.2010.0414.1420 UEFI BIOS: Capable Fábio Cury Gabriel
AlHill
The latest bios for your board is 5600 from July 2013. I have attached it.
Install this bios and test the board/keyboard again.
Doc
FGABR5
Thanks. I´ll install it and give you a feedback about the results. I tried to boot using another usb keyboard but the problem was the same. I will apply the Bios update. Bellow is the information about my keyboard: Device Manufacturer: N/A Product Name: USB Keyboard Serial Number: N/A USB Version Supported: 1.10 USB Device Speed: USB 1.1 Low-speed Driver Description: USB Composite Device Hardware ID: USB\VID_1A2C&PID_2C27 Driver Information Driver Manufacturer: (Standard USB Host Controller) Driver Description: USB Composite Device Driver Provider: Microsoft Driver Version: 6.1.7601.24138 Driver Date: 20-Jun-2006 DeviceInstanceId USB\VID_1A2C&PID_2C27\5&179A28A8&0&1 Fábio Cury Gabriel
FGABR5
Is this Bios Update to be installed using F7 BOOT Option? If so, do you have the Windows EXE version? Fábio Cury Gabriel
AlHill
F7 is what you want.
Follow Scott's procedure to the letter.
https://forums.intel.com/s/question/0D50P00004VhEOFSA3/how-to-upgrade-dz75ml45k-bios-from-0006-to-0017
Doc
AlHill
5A is "Resetting PATA/SATA bus and all devices"
You could have a HDD or even a CD/DVD drive that is dragging down your system. Unplug ALL unnecessary drives and boot.
Doc
FGABR5
The problem was solved and as I could see, it was related to some kind of corruption or bug associated with SATA DRIVES CONFIGURATION. The Parameter HARD DISK PRE-DELAY was set to ZERO (0), the default value. I changed it to 5 (five seconds) and after that, the POST time was reduced to 7 seconds, including the 5s of the hard-disk pre-delay parameter. After that, I returned the parameter to the default value ZERO (no delay) and Windows boot time returned to normal (before the problem).
OBS: The problem started after a video card replacement (the old one was defective).
I´d like to thank you for all your support and help.
Fábio.
AlHill
Glad you have it working.
Doc
