Items with no label
3340 Discussions
Greetings, I cannot get OpenVSwitch to add my DPDK-bound VFIO port (e1000 DPDK-compatible NIC) to the bridge without an error. I am supplying all of the info I know the community would typically ask me for, before I show the error at the end.
MWitt19
Hardware: Model: Dell Precision T-1700
CPU:
# lscpu
Architecture:         x86_64
CPU op-mode(s):       32-bit, 64-bit
Byte Order:           Little Endian
CPU(s):               4
On-line CPU(s) list:  0-3
Thread(s) per core:   1
Core(s) per socket:   4
Socket(s):            1
NUMA node(s):         1
Vendor ID:            GenuineIntel
CPU family:           6
Model:                60
Model name:           Intel(R) Core(TM) i5-4690 CPU @ 3.50GHz
Stepping:             3
CPU MHz:              1183.471
CPU max MHz:          3900.0000
CPU min MHz:          800.0000
BogoMIPS:             6983.91
Virtualization:       VT-x
L1d cache:            32K
L1i cache:            32K
L2 cache:             256K
L3 cache:             6144K
NUMA node0 CPU(s):    0-3
Flags:                fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm epb invpcid_single ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid xsaveopt dtherm ida arat pln pts md_clear spec_ctrl intel_stibp flush_l1d
# numactl -H
available: 1 nodes (0)
node 0 cpus: 0 1 2 3
node 0 size: 16019 MB
node 0 free: 7554 MB
node distances:
node  0
 0: 10
NOTE: I only have a single 4 core CPU, but it is Numa-enabled and Numa compatible, giving me one Numa Node with 4 cores.
Memory:
# lsmem --summary
Memory block size:      128M
Total online memory:     16G
Total offline memory:     0B
# cat /proc/cmdline
BOOT_IMAGE=/vmlinuz-3.10.0-1127.el7.x86_64 root=UUID=4102ab69-f71a-4dd0-a14e-8695aa230a0d ro rhgb quiet iommu=pt intel_iommu=on default_hugepagesz=1G hugepagesz=1G hugepages=4 transparent_hugepage=never LANG=en_US.UTF-8
A look at the kernel command line, which has iommu and hugepage directives
# cat /proc/meminfo | grep Huge
AnonHugePages:        0 kB
HugePages_Total:      4
HugePages_Free:       3
HugePages_Rsvd:       0
HugePages_Surp:       0
Hugepagesize:   1048576 kB
A look at how HugePages are allocated
# lsmod | grep vfio
vfio_pci              41412 0
vfio_iommu_type1      22440 0
vfio                  32657 3 vfio_iommu_type1,vfio_pci
irqbypass             13503 2 kvm,vfio_pci
Kernel Modules successfully loaded.
# /usr/share/dpdk/usertools/dpdk-devbind.py --status
Network devices using DPDK-compatible driver
0000:01:00.0 '82571EB/82571GB Gigabit Ethernet Controller D0/D1 (copper applications) 105e' drv=vfio-pci unused=e1000e
0000:01:00.1 '82571EB/82571GB Gigabit Ethernet Controller D0/D1 (copper applications) 105e' drv=vfio-pci unused=e1000e
Our DPDK-compatible NICs (p2p1 and p2p2 when not overridden with vfio) have been properly bound to DPDK.
Network devices using kernel driver
0000:00:19.0 'Ethernet Connection I217-LM 153a' if=em1 drv=e1000e unused=vfio-pci
0000:03:00.0 '82571EB/82571GB Gigabit Ethernet Controller D0/D1 (copper applications) 105e' if=p1p1 drv=e1000e unused=vfio-pci
0000:03:00.1 '82571EB/82571GB Gigabit Ethernet Controller D0/D1 (copper applications) 105e' if=p1p2 drv=e1000e unused=vfio-pci
These are the devices not bound to DPDK, em1, p1p1 and p1p2.
# ovs-vsctl list Open_vSwitch
_uuid              : ace95756-927f-4ceb-be27-76d0d5374461
bridges            : [2382d0c5-8955-4a27-b001-5fc606aabab8, 518c4675-a34a-43de-aedf-0eb9b44a7195, 77d5b674-2e0f-4311-9529-c7d1e2f1c344, 8ee6f680-63b1-42f0-b0ed-48807cbe49af, d0d3adca-e359-4b12-a775-b75647b98e47]
cur_cfg            : 369
datapath_types     : [netdev, system]
db_version         : "7.16.1"
dpdk_initialized   : true
dpdk_version       : "DPDK 18.11.0"
external_ids       : {hostname=maschinen, ovn-encap-ip="192.168.20.201", ovn-encap-type="geneve,vxlan", ovn-remote="tcp:192.168.20.200:6642", rundir="/var/run/openvswitch", system-id="35b95ef5-fd71-491f-8623-5ccbbc1eca6b"}
iface_types        : [dpdk, dpdkr, dpdkvhostuser, dpdkvhostuserclient, erspan, geneve, gre, internal, "ip6erspan", "ip6gre", lisp, patch, stt, system, tap, vxlan]
manager_options    : [8e30d191-ed8c-4f26-bc13-9f1087c0db25]
next_cfg           : 369
other_config       : {dpdk-init="true", dpdk-socket-limit="1024", dpdk-socket-mem="1024", pmd-cpu-mask="0x8"}
ovs_version        : "2.11.0"
ssl                : []
statistics         : {}
system_type        : centos
system_version     : "7"
OpenVSwitch initialized with dpdk (init=true), and our socket parms (1 Hugepage), and I even set a mdp-cpu-mask to 0x8 to ensure that I am using CPU core of 3 in the array [0,1,2,3].
# ovs-vsctl add-br br-testdpdk -- set bridge br-testdpdk datapath_type=netdev
We add a bridge in OpenVSwitch. No issue with this.
# ovs-vsctl add-port br-testdpdk p2p1 -- set Interface p2p1 type=dpdk options:dpdk-devargs=0000:01:00.0
ovs-vsctl: Error detected while setting up 'p2p1': Error attaching device '0000:01:00.0' to DPDK. See ovs-vswitchd log for details.
ovs-vsctl: The default log directory is "/var/log/openvswitch".
Adding the PCI 0000:01:00.0 (p2p1) to the bridge fails.
Also tried adding 0000:01:00.1 (p2p2) which also fails identical way.
# cat ovs-vswitchd.log
2020-05-04T21:12:11.071Z|00291|dpdk|ERR|EAL: Driver cannot attach the device (0000:01:00.0)
2020-05-04T21:12:11.071Z|00292|dpdk|ERR|EAL: Failed to attach device on primary process
2020-05-04T21:12:11.071Z|00293|netdev_dpdk|WARN|Error attaching device '0000:01:00.0' to DPDK
2020-05-04T21:12:11.071Z|00294|netdev|WARN|p2p1: could not set configuration (Invalid argument)
2020-05-04T21:12:11.071Z|00295|dpdk|ERR|Invalid port_id=32
Looking on the web for an answer to this, has not provided me any results. Everything up to this point looked just fine.
NOTE: I did a full yum update on the box, uninstalled openvswitch, and re-installed openvswitch.
NOTE: I did *not* do a custom build of DPDK or OpenVSwitch. I used yum to install dpdk, dpdk-tools, and openvswitch.
