Items with no label
3341 Discussions
Help mapping color to point
Hello everyone,
This has been asked before, and I believe I am doing the right steps but cannot get it work. I am trying to upgrade from RealSense to RealSense2 using SR300 camera. I am trying to abstract getting a point cloud with color (x, y, z, r, g, b) for other uses. I am trying to map the color to the depth points as follows:
Camera() : pipe(), pipeProfile(), depthScale(0) {
rs2::config cameraConfig;
cameraConfig.enable_stream(RS2_STREAM_DEPTH, 640, 480, RS2_FORMAT_Z16);
cameraConfig.enable_stream(RS2_STREAM_COLOR, 640, 480, RS2_FORMAT_RGB8);
pipeProfile = pipe.start(cameraConfig);
depthScale = pipeProfile.get_device().first().get_depth_scale();
void Camera::getCapture() {
rs2::frameset frames = pipe.wait_for_frames();
rs2::depth_frame depthFrame = frames.get_depth_frame();
rs2::video_frame colorFrame = frames.get_color_frame();
rs2_intrinsics depth_intrinsic = depthFrame.get_profile().as().get_intrinsics();
rs2_intrinsics color_intrinsic = colorFrame.get_profile().as().get_intrinsics();
rs2_extrinsics depth_to_color = depthFrame.get_profile().get_extrinsics_to(colorFrame.get_profile());
const uint16_t* depthImage = (const uint16_t*)depthFrame.get_data();
const unsigned char* colorImage = (const unsigned char*)colorFrame.get_data();
for (int dy = 0; dy < depth_intrinsic.height; dy++) {
for (int dx = 0; dx < depth_intrinsic.width; dx++) {
// get depth value at dy, dx
unsigned int i = dy * depth_intrinsic.width + dx;
uint16_t depth_value = depthImage[i];
// if the depth value is 0, we ignore this points.
if (depth_value == 0) {
continue;
float depth_in_meters = depth_value * depthScale;
// map the pixel coordinate in depth image to pixel coordinate in color image
float depth_pixel[2] = {(float)dx - 0.5f, (float)dy - 0.5f};
float depth_point[3], color_point[3], color_pixel[2];
rs2_deproject_pixel_to_point(depth_point, &depth_intrinsic, depth_pixel, depth_in_meters);
// if it's out of acceptable range, skip it
if (depth_point[2] > maxAcceptDistance) {
continue;
rs2_transform_point_to_point(color_point, &depth_to_color, depth_point);
rs2_project_point_to_pixel(color_pixel, &color_intrinsic, color_point);
// get closest color pixel obtained from calculations and use as the point's color, or white if ouside color image
const int cx = static_cast(color_pixel[0] + 0.5f);
const int cy = static_cast(color_pixel[1] + 0.5f);
// if outside intrinsic parameters, skip the point
if (cx < 0 || cy < 0 || cx > color_intrinsic.width || cy > color_intrinsic.height) {
continue;
const unsigned char* offset = static_cast(colorImage + (cy * color_intrinsic.width + cx) * 3);
float x = -1 * depth_point[0];
float y = -1 * depth_point[1];
float z = depth_point[2];
unsigned char r = *(offset);
unsigned char g = *(offset + 1);
unsigned char b = *(offset + 2);
I only left the redundant parts. Basically, in the end, (r, g, b) are 0 (or they appear black in the image). Any suggestions?
PS. (Code editor is weird).
For anyone that may read this, I had to swap the map_to and calculate statements. However, you also need to get some captures. do as follows:
rs2::pointcloud pc;
rs2::points points;
for (int i = 0; i < 10; i++) pipe.wait_for_frames();
rs2::depth_frame depth = frames.get_depth_frame();
rs2::video_frame color_frame = frames.get_color_frame();
pc.map_to(color_frame);
points = pc.calculate(depth);
int width = color_frame.get_width();
int height = color_frame.get_height();
const rs2::vertex* ptr = points.get_vertices();
const rs2::texture_coordinate* tex_coords = points.get_texture_coordinates();
const unsigned char* colorStream = static_cast<</span>const unsigned char*>(color_frame.get_data());
for (int i = 0; i < points.size(); i++) {
int x = static_cast(textureCoordinates[i].u * width);
int y = static_cast(textureCoordinates[i].v * height);
if (y < 0 || y >= height) {
continue;
if (x < 0 || x >= width) {
continue;
if (rs_vertices[i].z <= 0 || rs_vertices[i].z > maxAcceptDistance) { // Rule out values further than this value
continue;
int colorLocation = (y * width + x) * 3;
unsigned char color[3] = {colorData[colorLocation], colorData[colorLocation +1], colorData[colorLocation +2]}; // RGB
float coordinates[3] = { ptr[i].x, ptr[i].y, ptr[i].z };
MartyG
Have you seen the SDK 2.0 example for creating a point cloud?
https://github.com/IntelRealSense/librealsense/tree/master/examples/pointcloud librealsense/examples/pointcloud at master · IntelRealSense/librealsense · GitHub
Hello MartyG,
I did see the example, but I couldn't figure out how to use the (u, v) values to obtain the (r, g, b) values from the color frame. Any help with that? Thanks.
MartyG
I'll link RealSense stream programming expert jb455 into this discussion to seek his wide knowledge on the subject.
So I know that once you do
rs2::pointcloud pc;
rs2::points points;
Then, you can get the texture coordinates that correspond to each vertex:
const unsigned char* colorStream = static_cast(color_frame.get_data());
Each texture coordinate has (u, v) value which ranges from [0-1] that can be mapped to the color frame. I did this:
int x = tex_coords[i].u * color_intrinsic.width;
int y = tex_coords[i].v * color_intrinsic.height;
int colorLocation = y * color_intrinsic.width + x;
unsigned char color[3] = {colorStream[colorLocation], colorStream[colorLocation +1], colorStream[colorLocation +2]};
However, everything comes back as a single color. I stepped through and it seems both u and v are always 0.
rs2::pointcloud pc;
rs2::points points;
continue;
continue;
continue;
