Items with no label
3341 Discussions
Xcode + openFrameworks + RealSense SDK 2.0
PDeva2
I have some troubles adding RealSense SDK 2.0 to my openFrameworks/Xcode project.
Could anyone provide step-by-step instruction how to use SDK 2.0 with Xcode and openFrameworks, please?
I think it would be very helpful for the community.
Thank you!
MartyG
This documentation page explains how to build SDK 2.0 with XCode:
https://github.com/IntelRealSense/librealsense/blob/8e7db477a69741ca413a6b4d6402d19c8aace00e/doc/installation_osx.md librealsense/installation_osx.md at 8e7db477a69741ca413a6b4d6402d19c8aace00e · IntelRealSense/librealsense · GitHub
I was not able to locate support for OpenFrameworks on SDK 2.0 yet, unfortunately.
PDeva2
Yes, it works and I can build the project and run the examples.
The question is how to use SDK in my own Xcode projects. It is probably a question more about Xcode than RealSense SDK, i.e. how to link libraries etc.
I'll try to do it again and if everything works I will post the instructions here
MartyG
Thanks Petr.D - look forward to hearing how you did.
PDeva2
Apparently, it was quite easy. I'll upload the instructions and code snippets here later https://github.com/petr-devaikin/ofxRealSense2 GitHub - petr-devaikin/ofxRealSense2: Intel RealSense SDK 2.0 addon for openFrameworks
My plan is to make an oF addon, but let's see how far it will go
MartyG
Awesome news! I'm sure it would be a welcome contribution to the open-source SDK once you have your add-on working. Good luck!
