but i installed them manually so i'm pretty sure i've already got them updated but the program intel keeps telling me that i need to upgrade those 2 drivers, so i dont know if theres a new version of this program that detects drivers or if its something wrong with my drivers? thanks in advance
A new version of the Intel Driver & Support Assistant, v20.5.20.3 was released yesterday and should fix your issues. You can download it from here: https://downloadcenter.intel.com/download/28425/Intel-Driver-Support-Assistant?product=128824. If, after installing this new version, your first attempt to scan for updates fails, choose "rescan" and it should scan correctly.
Let us know if you experience any issues using this new version...
Hello XTrej,
To better assist you, please provide the following:
1. Run the Intel® System Support Utility (Intel® SSU) and attach the report generated:
- Open the application, check the "Everything" box, and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Use the paperclip icon to attach the report to the thread.
2. When you run the Intel® Driver & Support Assistant (Intel® DSA), what are the available driver updates that it shows? Can you please provide a screenshot of them?
Sebastian M.
