Items with no label
3338 Discussions
How do I get the depth of a specific pixel?
LRahi
For a computer vision application, we're trying to access the depth of four specific pixels. We tried to do that with several member functions of the "points" class but it didn't work.
Thanks for any help!
// ---Capture a snapshot via realsense   // Declare pointcloud object, for calculating pointclouds and texture mappings rs2::pointcloud pc; // Declare points object rs2::points points; //--Create a Pipeline - this serves as an API for streaming and processing frames rs2::pipeline pipe; //Create a configuration for configuring the pipeline with a non default profile rs2::config cfg; //Add desired streams to configuration cfg.enable_stream(RS2_STREAM_DEPTH, 640, 480, RS2_FORMAT_Z16, 30); //--Configure and start the pipeline pipe.start(cfg); //--Camera warmup - dropping several first frames to let auto-exposure stabilize auto frames = pipe.wait_for_frames(); //--Get one color and one depth frame rs2::frame color_frame = frames.get_color_frame(); rs2::depth_frame depth_fr = frames.get_depth_frame(); // Generate the pointcloud and texture mappings points = pc.calculate(depth_fr); // Tell pointcloud object to map to this color frame pc.map_to(color_frame); // Get depth coordinates and print them auto vertices = points.get_vertices();
MartyG
The link below has advice and scripting for getting the depth of a pixel in meters using the frame_get_distance instruction.
https://github.com/IntelRealSense/librealsense/wiki/Projection-in-RealSense-SDK-2.0#depth-image-formats
MartyG
