- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
I am performing some calculations regarding the FOV of the RGB module. If I use the 640x480 output resolution, is it correct to say that the final image is simply a cropped version of the original? In which case the HFOV would change from ~70 degrees to ~27 degrees (assuming the focal length [1.88 mm] is the same, and the sensor size is 33% of the total size, since the horizontal resolution is 640/1920 ~= 0.333).
Equation I am using:
FOV = 2 * atan( sensor_size / (2*focal_length) )
Thanks!
- Marcas:
- Intel® RealSense
Link copiado
0 Respostas
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
