Items with no label
3341 Discussions
How to activate multiple realsense cameras at the same time
HJian19
How to activate multiple realsense cameras at the same time? Or how can I choose that particular one when my computer has multiple different realsense cameras connected to it?
With the code below, the same camera is activated everytime but the other one never works.
//create the PXCSenseManager
PXCSenseManager* psm = 0;
psm = PXCSenseManager::CreateInstance();
if (!psm) {
wprintf_s(L"Unable to create the PSCSenseManager\n");
return 1;
//initialize the PXCSenseManager
if (psm->Init() != PXC_STATUS_NO_ERROR) {
wprintf_s(L"Unable to Init the PXCSenseManager\n");
return 2;
Hello Jhang,
Thanks for contacting Intel customer service.
In order for the multi camera feature to work you will need to use a Linux distribution and use Librealsense. In the following link you will find the ROS instructions on how to do it.
http://wiki.ros.org/librealsense
Using several RealSense devices with this method will lower the camera resolution.
Juan N.
HJian19
Thank you for your reply. I will try to solve my problem with a Linux distribution and Librealsense.
