Items with no label
3341 Discussions
How to correct the color in REALSENSE D415
侑劉
Hello everyone,
I use imatest to test color accuracy in REALSENSE D415.
The Color deviation is very large.
I want to correct color.
Cloud you offer solution to correct color for REALSENSE D415?
test environment: colorcheck 24 in test light box
light: D50
lux :500 Lux
MartyG
The 400 Series cameras have a calibration tool that you can use.
侑劉
Hi MartyG,
Thank you for your support.
I try it.it is for depth fine-tuning,not for color correct.
Could you have any solution for this issue?
MartyG
Color correction controls are provided in the 'Advanced Mode' of the 400 Series cameras. The Advanced Mode options can be accessed through the RealSense Viewer software.
1. Expand open the 'Stereo Module' options list.
2. Scroll down to the 'Advanced Controls' sub-option and expand that open.
3. Expand open the 'Color Correction' option.
侑劉
Hi MartyG,
thank you for your support.
I try it.I found color correct coe is 4x3 matrix.
I don't know the loaction color correct coe in the color matrix equation.
I don't fit color correct coe to software setting.
could you offer 4x3 color matrix equation ?example: 3x3 color matrix
by the way,I found inital config(xx.json).
the json file has two color corrcection coe, what self for application?
I want to correct color in the RGB sensor, which one I select it ?
MartyG
The documentation says about the 400 Series cameras' extrinsics:
"The rotation field contains a 3x3 orthonormal rotation matrix between the imager's physical orientations ... Knowing the extrinsic parameters between two streams allows you to transform points from one coordinate space to another, which can be done by calling rs2_transform_point_to_point. This operation is defined as a standard affine transformation using a 3x3 rotation matrix and a 3-component translation vector."
I do not have an answer for your JSON question, unfortunately. Hopefully someone else can offer useful advice on that.
