Items with no label
3341 Discussions
Ubuntu get depth image and video stream
zchen38
hi,
I want to do some image processing using depth and RGB stream of realsense D435 camera. but i am not able to integrate opencv with realsense sdk. how can i receive depth frame and RGB frame in Mat variable of opencv so that i can do some processing in it.
thanks !!
PS:If I want to program on ubuntu 16.04 and KDevelop with D435, what should I write in the CMakeLists.txt?
MartyG
Developer UnaNancyOwnen has produced some sample programs for SDK 2.0 that use OpenCV. The code in these samples may be of use to you.
http://unanancyowen.com/en/realsense-sdk-2-samples/ Intel RealSense SDK 2 (librealsense2) Sample Program – Summary?Blog
https://github.com/UnaNancyOwen/RealSense2Sample/tree/master/sample RealSense2Sample/sample at master · UnaNancyOwen/RealSense2Sample · GitHub
I do not have information on your second question about CMakeLists, unfortunately. Hopefully someone can provide you with information about that. Good luck!
zchen38
zchen38
Do you know how to get the left and right color images and infrared images?
MartyG
A script for getting left and right infrared streams was given on this page:
And this page discusses creating a a color stream:
I did what you are trying to do. Check https://github.com/ToshiEAB/RealSense GitHub - ToshiEAB/RealSense: Sample C++ programs for running a RealSense camera (SR300, D415, and D435 models) on Window…
zchen38
