Items with no label
3340 Discussions
How to hard reset BIOS setting on Euclid?
YKame1
Please tell me how to hard reset BIOS setting on Euclid?
Amit_M_Intel
Use this .fv file : https://tinyurl.com/ydhr3kno https://tinyurl.com/ydhr3kno
and copy the file(with sudo) to /boot/efi/BIOSUPDATE.fv
Reboot the device.
Amit
MartyG
Hard reset refers to a reset to factory defaults.
On the Euclid's web interface, there should be a tab option called 'Power'. Under this should be 3 options, one of which is 'Restart OOBE'. OOBE stands for Out Of Box Experience - the initial setup process when Euclid is first taken out of the box after you have purchased it. I do not know if OOBE resets the BIOS settings to factory default too though.
Amit_M_Intel
Reboot the device.
Amit
