Items with no label
3340 Discussions
How to perform obstacle avoidance using realsense D435 camera data in dynamic environment , is there any Library/code available for doing the same ?
sacha13
while the ground bot is moving with the help of visual preception from D435 , can we perform obstacle avoidance WITHOUT using any custom Object Detection algorithm ; any support from Intel Realsense out of the box
MartyG
The Librealsense SDK does not have obstacle detection built in as a ready-to-go function. You could possibly use the ROS vision software, which the SDK fully supports. Intel have an 'Object Analytics' package for ROS, which can provide obstacle detection.
https://github.com/intel/ros_object_analytics
