Items with no label
3341 Discussions
How to scan very close objects using SR300 ? (mirror, multiple cameras ?)
NRaul
Hi guys,
I've been trying to 3D scan objects from a very close range. The object I wanna scan is about 32cm long so I have to be at least 30cm away from it to be able to get the entire shape (I could scan it from 20cm but I would not have the entire object inside my scanning area).
Here are the tests I've performed and the limits I encountered:
  • Moving the camera: this could work but it is something I don't wanna do, I'd like to perform an instant 3D capture
  • Using an angled mirror and scanning through it to reduce the maximum distance: this is the best solution I could find but I have limited results due to saturation (reflects in the mirror) and I cannot scan sharp angles (with an equivalent distance using a mirror vs direct scanning, the maximum angle that I can scan is smaller using the mirror. For example, if I try to scan a sphere with a mirror, the scanned surface would be smaller than directly scanning it)
  • Using multiple cameras? I didn't try to do it yet, is it easy to get an automated reconstruction of the two or more scans?
Would you have any advice or suggestion on how to reduce the height between the scanner and the object?
Hello NicolasR,
Thank you for your interest in the Intel® RealSense™ Camera SR300.
The depth range of the camera is (approximately) 20 cm to 150 cm. So it is not possible to reduce the distance below the 20 cm that you have already tried.
Regarding the multiple camera alternative, I'll recommend you to check the following community threads for more information:
How to use multiple SR300 looking at the same object
/message/484501# 484501 https://communities.intel.com/message/484501# 484501
Multiple Camera and 3D Point Cloud Problems
/message/464565# 464565 https://communities.intel.com/message/464565# 464565
Streaming from two cameras
/message/460597# 460597 https://communities.intel.com/message/460597# 460597
Please let me know if you find this information useful.
Andres V.
Hello NicolasR,
I was wondering if you could check the suggestion provided.
If you have any update or question, don't hesitate to contact us.
Andres V.
