Items with no label
3341 Discussions
Timeout waiting for frames.
BMane1
I am facing two weird problems with Euclid. Does anyone know how can I solve them or what is the reason?
1- I returns: "Timeout waiting for a frames" for a simple application like :
https://github.com/IntelRealSense/librealsense/blob/zr300_documentation/doc/stepbystep/getting_started_with_openCV.md librealsense/getting_started_with_openCV.md at zr300_documentation · IntelRealSense/librealsense · GitHub
However once I debug it using a breakpoint, it works properly.
2- It does not boot once I use the "Power Adapter Plate" But it works properly with the battery.
Thanks very much.
Hello bmanesh,
Thank you for your interest in the Intel® Euclid™ Development Kit.
I'll be needing more time to review your inquiry and suggest something to solve the issue you are experiencing, as soon as I have relevant information I'll post it here.
Thank you for your patience.
Andres V.
Tsahi_M_Intel
Hi bmanesh,
For issue 1:
The current Euclid implementation uses a forked version of librealsense.
Main changes are in the synchronization component and this is why you did not get any frames.
Please remove any modified librealsense version and changes made to camera setup, or just run factory reset.
Issue 2:
Are you using the power adapter connected to the same power charger you received with Euclid ?
Tsahi.
Intel Euclid Development Team.
Hello bmanesh,
I was wondering if you could check the suggestion provided and the question asked by Tsahi.
If you have any update or question, don't hesitate to contact us.
Andres V.
