Your Sandy Bridge processor is not supported on Windows 10, nor is its graphics.
Make certain that you are on Windows 10 version 1909.
Make certain that your motherboard bios is up-to-date:
https://www.gigabyte.com/Motherboard/GA-H67MA-USB3-B3-rev-10/support#support-dl-bios
Make certain that the latest ME is installed:
https://www.gigabyte.com/Motherboard/GA-H67MA-USB3-B3-rev-10/support#support-dl-driver-chipset
Check to see if you hdd is failing.
Check to see if you have memory problems.
If none of this works, you may be out of luck.
Doc
