Items with no label
3340 Discussions
I want to know if there is a driver for "g45/g43 express chipset" that works with windows10. thanks
LDaca
When I tried to update my current so, windows7 to windows10, it appears a message telling me that my chipset wont work properly with windows 10, and that i could have problems.
I will apreciate if someone could help me, I have an all in one computer,
AlHill
The G45/G43 is discontinued and not supported. On WIndows 10, with this chipset, you will be using the Microsoft generic driver, which lacks in performance and features. There is no update that you can use.
Doc
n_scott_pearson
For all standard motherboard and (Core 2 Duo/Quad) processor features, the drivers are provided with Windows 10 and will install automatically as part of the Windows 10 install/upgrade processes. The one exception is graphics. The graphics engine built into the chipset (GMCH component) is specifically NOT supported by Intel on Windows 10. Microsoft provides a compatibility driver that will allow this graphics engine to be used, but the performance of this solution is mediocre at best and interface support (OpenGL, etc.) is very old. Microsoft is no longer maintaining this compatibility driver, so any issues uncovered (I have read reports of at least two issues in the past few months) will NOT be fixed. What you see is what you get.
Obviously, my primary recommendation is to replace this whole system with something modern. If you must use it, my secondary recommendation is to find an add-in graphics card that you can use with it (good luck, these are difficult to find).
